Pioneer DJM-707 and DJM-909
(67 reacties. Pagina 1 van 7)Moderator(s): Dré
| BramcomStandaard Lid Uit: Nederland Sinds: 8-10-2003 Laatste: 29-12-2008 Berichten: 73 | 24-10-2003 14:18 |
| engelse review die ik hierover had: The DJM-909 and DJM-707 High Quality Sound Design and Durability The DJM-909 and DJM-707 boast the highest quality in sound and design that exceed today’s battle / performance mixers offering powerful club sound in a battle mixer. This was accomplished with sensitive yet solid gripping EQ knobs, durable transform switches, and precise and accurate cross fader curve control. Most importantly, Pioneer has developed an original “non-contact” cross fader technology with unprecedented durability and reliability. The Cross Fader and Faders The most important feature on any battle mixer is its cross fader and fader performance. Pioneer’s DJM-707 and DJM-909 introduce the most precise and customizable cross fader in the industry to date. The cross fader is highly durable and has double fade control allowing each half of the cross fader the ability to be adjusted independently! All fader curves can also be seen and adjusted with visual reference on the mixers’ fader curve adjust screen (DJM-909). If that isn’t enough, the cross fader feel can also be adjusted to your preference (a breakthrough functionality). Each channel fader curve can be adjusted from a smooth volume change to a dynamic volume ON/OFF at the TIP of the channel faders (bottom or top). In turntablist slang, you will be able to crab-scratch the channel faders from either the top end or bottom end of the fader. Fader Start Sync Both mixers can connect with Pioneer’s CDJ series to employ the fader start capability. The user can automatically start or stop playback by the sliding cross-fader or channel-fader. Mixer Layout Both the DJM-707 and DJM-909 are similar in layout although the DJM-909 boasts built-in effects and a touch sensitive display. Both mixers also offer a very clean, open fader area for scratching and beat juggling. Both mixers have a session line-in with volume control, cueable master output, mic input, and selectable phono / line switches. In addition, the DJM-909 has a tempo tap button, cueable effects switch, and a plug in for foot switch to control effects. Additional Features of the DJM-909 - TOUCH SCREEN AND BUILT IN EFFECTS A total of fifty different effects incorporated in the DJM-909 can be independently assigned, utilized, & tweaked through the mixers’ user friendly touch screen control. Additional knobs also exist for further parameter adjustments. Revolutionary effect presets range from Fader Synths to Transform and from Touch Phaser to Vocoder. A send/return is also built-in to connect an external effector. - FADER EFFECT Fader effect can be assigned to a channel fader or cross fader from the touch screen so that the faders are capable of controlling and varying the effect’s parameter simply by moving the cross fader or channel fader. - BEAT EFFECT The Beat Effect is capable of synchronizing effects with the BPM for high accuracy effect timing. - AUTO BPM COUNTER The mixer is equipped with an auto BPM counter so users can quickly view the song tempo. Pioneer’s DJM-707 and DJM-909 were designed with scratch DJs, the studio / production DJs and the Turntablist in mind, however they are also excellent units for all DJs wanting to improve their performance level. The introduction of these two revolutionary mixers has taken the high-end battle mixer into a whole new dimension. The DJM-909 and DJM-707 will be available in December at a minimum advertised price (MAP) of $1,199 and $699 respectively. Pioneer offers a complete line of Pro DJ Equipment through its Pro Audio Group. Pioneer offers a limited one-year warranty for Pro Audio products purchased from authorized dealers. For more information: www.PioneerProDj.com. Pioneer Corporation is a leader in optical disc technology and a preeminent manufacturer of high-performance audio, video, computer and cable equipment for the home, car and business markets. The company focuses on four core business domains including DVD, display technologies, Digital Network Entertainment and components. Founded in 1938 in Tokyo, Pioneer Corporation employs more than 34,000 people worldwide. Its shares are traded on the New York Stock Exchange (NYSE:PIO). Pioneer's U.S. headquarters is located in Long Beach, Calif., and its U.S. Web address is www.pioneerelectronics.com. ### Specifications For The DJM-909 and DJM-707 Input Terminal (Input Level / Impedance) CD 1, 2 -14dBV (200mV) / 22k LINE 1, 2 -14dBV (200mV) / 22k PHONO 1, 2 -54dBV (2mV) / 47k MIC -54dBV (2mV) / 3k SESSION IN -14dBV (200mV) / 22k RETURN -7.2dBV (437mV) / 22k Output Terminal (Output Level / Impedance) MASTER OUT 1 (XLR) 2.2 dBV (1.23V) / 60k MASTER OUT 2 (RCA) 0 dBV (1V) / 1k BOOTH/SESSION OUT 0 dBV (1V) / 1k SEND -14 dBV (200mV) / 1kO Headphone Maximum Output (Output Level / Impedance) PHONES 0 dBV(1V)/22 Frequency Response LINE/MIC 20Hz to 20kHz PHONO (RIAA) 20Hz to 20kHz Signal-to-noise Ratio LINE 87dB PHONO 77dB MIC 64dB Distortion Rate CD, LINE 0.02% or less Cross Talk (1kHz) 70dB or more Channel Equalizer (LINE/PHONO) HI -26dB to +6dB MID -26dB to +6dB LOW -26dB to +6dB Mic Equalizer (MIC) HI -12dB to +12dB LOW -12dB to +12dB Power & Physical Power Requirements N. America - AC 120V, 60Hz / Europe - AC 220-240V, 50/60Hz Power Consumption N. America - 31W / Europe - 30W / Japan 27W Dimension (W x D x H) 251 x 381.6 x 107.9 (mm) / 9.9 x 15 x 4.2 (inches) Weight DJM-909 - 6.5 kg (14.3 lbs) / DJM-707 - 6.3 kg (13.9 lbs) plaatjes: www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16236.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16239.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16240.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16244.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16243.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16241.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16238.jpg wat vinden jullie van deze mixer? | |
| maximaal 120 tekens. Wel tekst, geen link! | |
| DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 19-9-2026 Berichten: 13452 | 24-10-2003 14:43 |
| Ik hoop dat Pioneer erachter gekomen is dat een voeding niet per sé een straalkachel hoeft te zijn... Ook hoop ik dat Pioneer ontdekt heeft dat 6dB headroom niet echt hoort bij profi spulletjes (20dB komt eerder). | |
| ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 25-10-2003 00:23 |
Dré schreef: Ik hoop dat Pioneer erachter gekomen is dat een voeding niet per sé een straalkachel hoeft te zijn... | |
| DiederikStandaard Lid Uit: Nederland Sinds: 20-5-2003 Laatste: 3-2-2021 Berichten: 615 | 25-10-2003 19:57 |
Reind schreef: Dré schreef: Ik hoop dat Pioneer erachter gekomen is dat een voeding niet per sé een straalkachel hoeft te zijn... Het is te hopen dat Pioneer zich idd wat heeft aangetrokken van de kritiek op de DJM, en dat meegenomen heeft. Ik neem tenminste niet aan dat dit het enige forum is waar wat kritiek is op de DJM 500/600 Wel vind ik de aansluitingen en aanduidingen zo op het eerste gezicht nogal op mekaar gepropt. D'r zit wel logica in, en met alle wenselijke aansluitingen erop (balanced & unbalanced out etc.), maar verder zit het allemaal een beetje op mekaar en door elkaar. Ik had het denk ik niet zo ontworpen. | |
| Wat nu heel gewoon is, was ooit een revolutie | |
| Dj diëgoStandaard Lid Uit: Nederland Sinds: 21-9-2003 Laatste: 3-2-2010 Berichten: 136 | 25-10-2003 20:42 |
nou ik vind em eigenlijk HEEL mooi niet te druk als je het mij vraagt ook een hele mooie display! | |
| Who ever said life is short it's the longest goddamn thing you do, are you gonna do something that's longer! | |
| HendrikStandaard Lid Uit: Nederland Sinds: 15-2-2002 Laatste: 12-8-2013 Berichten: 296 | 25-10-2003 21:47 |
| Hmmm, Als ik ooit met een touchscreen op pad zou gaan dan zou hij wezen voor: 1 M'n lichttafel (maar dat kan ik niet betalen) 2 Voor karaoke (maar dat doe ik niet) 3 Voor MP3 (maar ik spring nog liever voor de trein) Als ik de weg kwijt ben vraag ik wel een dame, koop ik een autokaart of desnoods een navigatiesysteem voor in de auto. Maar ik hoef geen GPS in m'n mixer. Ook nog even serieus. 50 functies over touchsreen????? Allemachtig. Als je die allemaal gebruikt in je sessie ben je volgens mij ook recordhouder "langste DJ-sessie ooit". Die toestanden op de voorkant vind ik buitengewoon eng, achterkant niet echt overzichtelijk. Er zijn natuurlijk heel veel mensen die de DJM500/600 of misschien zelfs de 300 helemaal geweldig vinden, die zullen dit geval vast ook helemaal te gek vinden. En misschien is deze ook wel wat. (als reserve-backup-inval mixer voor in de bejaarde soos, just kidding )Nee, geef mij maar echte knoppen en niet teveel van die doelloze shit erin (kan allemaal kapot gaan joepiedepoepie). Moet tegenwoordig in alles een display zitten? Dan mag ik mijn broodrooster wel eens vervangen. Neemt niet weg dat ik dit ding toch wel even wil testen . | |
| ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 26-10-2003 00:11 |
Hendrik schreef: Neemt niet weg dat ik dit ding toch wel even wil testen . Ik ben wel benieuwd naar deze mixers en helemaal naar hun prestaties. | |
| BramcomStandaard Lid Uit: Nederland Sinds: 8-10-2003 Laatste: 29-12-2008 Berichten: 73 | 27-10-2003 14:48 |
| rond 2004 komt hij (zucht hoe toevallig in januari of december)? maar hij ziet er wel leuk uit (al geef ik tocoh de voorkeur voor zilver en een WIT display. Oranje vindt ik zo oudlullig ^_^ maar goed we zullen toch ff moeten wachten op de eerste reviews, want de specificaties zeggen niet alles ;-) Bram... | |
| SnakeEffect Guru Uit: België Sinds: 17-2-2003 Laatste: 19-4-2014 Berichten: 675 | 27-10-2003 21:26 |
| 't Is niet meer zo erg als vroeger (toen een witte led nog een slordige € 25 kostte), maar een witte LED is duurder dan een oranje. Dit komt omdat wit licht het volledige zichtbare kleuren spectrum moet uitzenden. Me dunkt dat Pioneer wat wilt besparen. | |
| DJ TimStandaard Lid Uit: Nederland Sinds: 9-6-2003 Laatste: 27-11-2012 Berichten: 1105 | 27-10-2003 21:33 |
| Ziet er strak uit! Zou hem best wel eens in mijn vingers willen hebben. Ik hoop dat Pioneer nu wel de goeie kant opgaat met hun mixers. | |
| Ik ben niet het eerste wereldwonder maar ben er wel geweest |
