nieuw dingetje van hercules (foto's + lange lap text)
(118 reacties. Pagina 1 van 6)Moderator(s): Dré
| QuincManStandaard Lid Uit: Nederland Sinds: 1-8-2003 Laatste: 15-5-2010 Berichten: 783 | 4-10-2003 15:30 |
1 x bewerkt. Laatst door Tom op 9-10-2003 15:25 www.casejunkies.com/images/artikel_upload/picture_2986.jpgDJ Console: Fun, easy mixing/scratching dual vinyl-style decks Mix, scratch and manipulate digital music in real time, from MP3s, WMAs to CDs Solid design with phosphorescent keys perfect for use under low-light conditions at parties Tactile controls for vastly superior DJ mixing than with a PC keyboard Take full control of your music with the DJ Console! Scratch audio files and CDs Adjust cue points to create great loops Adjust BPM (Beats Per Minute) for smooth transitions between tracks Speed up/slow down music Optimized DJ sound Play one track for your audience while previewing another on your headphones to create seamless mixes Add voice-overs by lowering the music volume with the click of a button, allowing you to talk to your public An advanced sound card for your PC 16-bit/48KHz sampling, 24-bit ADC/DAC 5.1-channel analog output High-quality connectors: Digital optical/coaxial In/Out MIDI In/Out 5.1-channel output via minijack (3.5mm) or RCA plugs Stereo Line Input (2 RCA plugs) ¼ inch (6.35mm) stereo microphone Input ¼ inch (6.35mm) stereo headphone Output Totally portable: bring it anywhere! USB bus-powered device: no external power source required Compact size: 235x200x650mm (cover included) DJ Console includes: a protective cover that doubles as an inclined base a shoulder strap for easy transportation Bundled software Virtual DJ from Atomix Productions, a full professional DJ software suite New DJ SE from GMIXON, the easy-to-use DJ mixing software OTS CD Scratch and OTS DJ demo from OTS Audio, a virtual turntable CD player and a revolutionary MP3/CD/WAV playback system for DJs, radio stations and music lovers Storm 2.0 DJ Edition from Storm Music Studio, a powerful audio sequencer DJ Console Softmapper from Hercules, a powerful mapping interface allowing you to assign keyboard shortcuts to your DJ Console’s controls for hands-on control of audio applications (mapping of digital controls only) TECHNICAL SPECIFICATIONS Front Panel Input - Stereo Line In: 2 RCA input plugs - Gain/talkover button for microphone input control - ¼ inch (6.35mm) stereo microphone input plug Output - Headphone volume control - ¼ inch (6.35mm) pre-amplified stereo headphone output plug Rear Panel Analog audio output - 6 RCA output plugs for 5.1-channel audio - 3 1/8 inch (3.5mm) stereo output plugs Digital audio - Coaxial Input and Output plugs - Optical Input and Output plugs MIDI - Din 5-pin Midi In and Midi Out plugs USB plug Top Panel - 2 vinyl-style decks - 8 knobs - 3 sliders - 28 soft phosphorescent buttons - 1 mini-stick - 16 LEDs Audio specifications - 6-channel audio sampling in 16-bit/48KHz mode - 24-bit 102dB ADC, 24-bit 106dB DAC - Optical and coaxial S/PDIF digital In & Out (up to 24-bit) Compatibility USB - USB 1.1 (USB Full-Speed) required - Compatible with USB 2.0 (USB High-Speed) - Due to the need for a full USB power supply, a dedicated USB root hub is recommended - 2m USB cable included Audio - Microsoft® DirectSound® compatible - ASIO 2.0 drivers included - General MIDI™ compatible SYSTEM REQUIREMENTS - Desktop/laptop PC with Intel Pentium II 400MHz or compatible - 64MB RAM - Operating system: Microsoft Windows 98/98 SE, Me, 2000, XP - USB 1.1 or USB 2.0 port (dedicated USB root hub recommended) - Headphones or amplified speakers - CD-ROM or DVD-ROM drive (CD-DA support recommended) - Microphone, Internet connection + 100MB free hard disk space for installing bundled software en nog wat foto's europe.hercules.com/images/products/87/dj_front.gif europe.hercules.com/images/products/87/dj_rear.gif prijs zal rond de 250 euro liggen, ik hou het toch liever bij mijn eigen setje... alhoewel dit ook wel aantrekklijk (lijkt) gezien mijn omstandigheden wat denken jullie hiervan? top of flop? Edit Mod: volgende keer zelf even de loze regels verwijderen, en alleen links gebruiken voor de plaatjes aub,pffffff nou een bav | |
| SybrandStandaard Lid Uit: Nederland Sinds: 11-5-2003 Laatste: 2-7-2005 Berichten: 212 | 4-10-2003 15:36 |
| voor die prijs? Nou ja, als het echt wat is! dan zal hij top zijn Ik vind alleen dat het uiterlijk nogal aan Bart Smit doet denken | |
| Blijf possitief, ook als het te moeilijk is! | |
| YoghurtStandaard Lid Uit: Nederland Sinds: 11-8-2002 Laatste: 6-8-2023 Berichten: 902 | 4-10-2003 15:43 |
Play & Que knopjes lijken beetje op die van de Numark cdn 36... Heeft er wel iets van weg... Verder vind ik het een oerlelijk ding...Maar als het het goed doet... grtz | |
| SnakeEffect Guru Uit: België Sinds: 17-2-2003 Laatste: 19-4-2014 Berichten: 675 | 4-10-2003 15:53 |
| Wat ik vreemd vind bij deze prijs is dat er midi-in en midi-out aanwezig is. Verder ziet het me er niet echt betrouwbaar uit, het lijkt wel speelgoed eigenlijk. | |
| QuincManStandaard Lid Uit: Nederland Sinds: 1-8-2003 Laatste: 15-5-2010 Berichten: 783 | 4-10-2003 16:45 |
| het is eigenlijk een soort externe geluidskaart voor de pc met wat knopjes er op... dus ik persoonlijk denk dat dit leuk bed8 is voor thuisgebruikers en voor die conrad gastjes maar voor echt drive in gebruik zou ikz elf voor een "echte" set gaan hercules is nl aardig bekend in de pc wereld (oa radeon gpu's) | |
| Dj JasperStandaard Lid Uit: Nederland Sinds: 3-6-2003 Laatste: 7-9-2018 Berichten: 393 | 4-10-2003 17:20 |
| Hier moetje toch gewoon nog een cd-speler op aansluiten? Dan heb je ook helemaal niks aan al die functies? Die zitten dan op je cd-speler! | |
| DawizzeStandaard Lid Uit: België Sinds: 24-12-2002 Laatste: 9-6-2005 Berichten: 15 | 4-10-2003 17:57 |
dj Jasper schreef: Hier moetje toch gewoon nog een cd-speler op aansluiten? Dan heb je ook helemaal niks aan al die functies? Die zitten dan op je cd-speler!Het is gewoon een externe controller voor mixprogramma's op de computer zoals atomix ed. Het zelfde principe als bpm studio ed, die heeft ook een bijhorende controller. Mvg Wim | |
| ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 4-10-2003 18:48 |
| tsja je hebt er geen raat aan bij je dj set want hij heeft geen uitgang per kanaal en dus kun je hem niet aansluiten op je mixer (naja kan wel maar fijn is een ander verhaal). | |
| QuincManStandaard Lid Uit: Nederland Sinds: 1-8-2003 Laatste: 15-5-2010 Berichten: 783 | 5-10-2003 11:29 |
| lol dit is volges mij ook niet zo'n hufter proof apparaat... leuk voor die conrad boys maar niet voor echte dj's/drive-in's... daar heb je bpm/atomix/fruityloops/pcdj/etc. voor | |
| RoeltjeStandaard Lid Uit: Nederland Sinds: 19-1-2003 Laatste: 30-9-2015 Berichten: 505 | 5-10-2003 15:40 |
| Lijkt me ook bedoelt voor de thuismarkt, mensen die thuis achter hun pc een beetje met muziek willen pielen. | |
| vaj-ta-lie-tie | |
| Dj NathanStandaard Lid Uit: Nederland Sinds: 5-12-2002 Laatste: 23-1-2013 Berichten: 264 | 9-10-2003 13:07 |
| Ik heb wat gezocht en het is een externe controller voor mp3's ism automix maar met deze kan je dus ook scratchen. En dit apparaatje is een stuk goedkoper namelijk: 192.50 excl BTW www.aa24.nl/ hier staat wat meer. Als het werkt is het een leuk piele dingetje voor niet te veel geld. Bij die 200 euro zit ook automix en nog wat software | |
| Pearl 2000 in da house!! | |
| DimitriStandaard Lid Uit: Nederland Sinds: 30-8-2003 Laatste: 12-1-2015 Berichten: 25 | 29-10-2003 23:21 |
| Eindelijk een review erover gevonden, helaas in het Frans, maar op op babelfish.altavista.com kan je em laten vertalen naar Engels (leest volgens mij stuk makkelijker).Review staat op: www.tomshardware.fr/articleav.php?IdArticle=451&NumPage=1 Conclusion The DJ Console can be regarded as a product of niche for the sound on PC but it is a niche targeted particularly well and which is in full expansion. Hercules knew to form part of a tendency which touches the world of the DJ and the innumerable amateurs who revolve around. To pass from "true" vinyl with all the heavy material which accompanies it with the numerical, easily transportable whole and usable anywhere does not miss an attraction nor of interest. If the mixing of animation tries you, the DJ Console is certainly the best means making it possible to approach it in an effective way at a limited cost and, if you are already initiated, it can be a new tool which will open interesting prospects to you. | |
| Logica brengt je van A naar B, verbeelding brengt je overal | |
| PimWStandaard Lid Uit: Nederland Sinds: 13-4-2003 Laatste: 15-12-2010 Berichten: 207 | 7-12-2003 21:45 |
| Op www.hardware.info en www.clubcharts.nl staat een review online. De conclusie is naar ik meen ongeveer hetzelfde als op die Franse website. Leuk voor de thuisgebruiker, maar meer ook niet. | |
| Ron TimmersStandaard Lid Uit: Nederland Sinds: 13-3-2004 Laatste: 13-3-2004 Berichten: 2 | 13-3-2004 22:56 |
| Nou, ik heb me er eentje bemachtigd... Dit is alweer zo'n 4/5 maanden geleden.... Ennuh... NIET aan beginnen! 1. Autopitch (dus voor de beginners wel leuk) 2. Pitch gaat nogal redelijk vaak zijn eigen gang, en dat kan je de bloed onder de nagels uithalen... En dit vind ik ook de grootste minpunt. 3. Software blijft nogal eens hangen. 4. Hij heeft vaak een late reactie (bijv. als je de crossfader naar links zet dat die pas 1 seconden later ook pas echt op je scherm naar links gaat) 5. Play knop moet je te hard op rossen. 6. neej, mijn computer heeft het dubbele van de minimum systeem eisen en is een stabiel systeem dus het is puur de software/drivers. Nou, hier heb ik ff een paar punten neer gezet waarvan ik zeg..... Die moet je ff weten. TIP! Als je begint met de dj'en weet ik zeker dat je hier veel lol mee kunt hebben!! Maar, als je een beetje de profi kant op wilt is dit een echte afrader! vragen, mail me: [email protected] | |
| beginnend DJ/Producer | |
| Da romeoStandaard Lid Uit: Nederland Sinds: 13-2-2004 Laatste: 29-4-2004 Berichten: 3 | 16-3-2004 17:10 |
| kan je dit ding gebruiken, EN mengpaneel ? grtzzz | |
| QuincManStandaard Lid Uit: Nederland Sinds: 1-8-2003 Laatste: 15-5-2010 Berichten: 783 | 16-3-2004 17:19 |
| nope dit is alles in een, dus aan je computer hangen en gaaan... | |
| ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 18-3-2004 02:31 |
| Ik heb er laatst ff mee staan spelen en tis te vergelijken met een home mix geval qua kwaliteit. Leuk om thuis te prutsen achter de pc maar dan moet je niet zeiken over delay's of iets dergelijks want dan houd het op. Ding was trouwens als uit elkaar aan het lazeren toen ik er mee bezig was. Play knopje bleef hangen in de behuizing en het fader knopje lag er ook binnen no time af. Tsja wat wil je ook voor dat geld. | |
| HjvogelpoelStandaard Lid Uit: Nederland Sinds: 3-9-2003 Laatste: 21-1-2010 Berichten: 141 | 19-3-2004 14:26 |
| delays oh dat is makkelijk tijdens het beatmixen :P what you pay is what you get | |
| AlexnautaStandaard Lid Uit: Nederland Sinds: 25-3-2004 Laatste: 11-4-2004 Berichten: 6 | 25-3-2004 11:37 |
| Ik heb hem morgen ook binnen, de problemen waarover gesproken wordt (delay & pitch die z'n eigen gang gaat) zijn op te lossen door een firmware/driver update te downloaden van Hercules, het zijn namelijk wat probleempjes die in de eerste oplage's zaten van de DJ console. Verder hangt het één en ander ook af van het programma dat je erbij gebruikt, genoeg mogelijkheden :) | |
| Webmaster Harlingers | |
| DJ TimStandaard Lid Uit: Nederland Sinds: 9-6-2003 Laatste: 27-11-2012 Berichten: 1105 | 25-3-2004 23:30 |
| Ben wel van mening dat je een en ander met firmware kunt oplossen, maar dan blijven de knopjes en de fadertjes nog steeds van inferieure kwaliteit. Niettemin, denk dat er in de zeer nabije toekomst wel kwalitatief goeie consoles, of nog beter, harddisk players uit zullen komen. | |
| Ik ben niet het eerste wereldwonder maar ben er wel geweest |
