Pioneer DJM-707 and DJM-909
(67 reacties. Pagina 1 van 4)Moderator(s): Dré
| BramcomStandaard Lid Uit: Nederland Sinds: 8-10-2003 Laatste: 29-12-2008 Berichten: 73 | 24-10-2003 14:18 |
| engelse review die ik hierover had: The DJM-909 and DJM-707 High Quality Sound Design and Durability The DJM-909 and DJM-707 boast the highest quality in sound and design that exceed today’s battle / performance mixers offering powerful club sound in a battle mixer. This was accomplished with sensitive yet solid gripping EQ knobs, durable transform switches, and precise and accurate cross fader curve control. Most importantly, Pioneer has developed an original “non-contact” cross fader technology with unprecedented durability and reliability. The Cross Fader and Faders The most important feature on any battle mixer is its cross fader and fader performance. Pioneer’s DJM-707 and DJM-909 introduce the most precise and customizable cross fader in the industry to date. The cross fader is highly durable and has double fade control allowing each half of the cross fader the ability to be adjusted independently! All fader curves can also be seen and adjusted with visual reference on the mixers’ fader curve adjust screen (DJM-909). If that isn’t enough, the cross fader feel can also be adjusted to your preference (a breakthrough functionality). Each channel fader curve can be adjusted from a smooth volume change to a dynamic volume ON/OFF at the TIP of the channel faders (bottom or top). In turntablist slang, you will be able to crab-scratch the channel faders from either the top end or bottom end of the fader. Fader Start Sync Both mixers can connect with Pioneer’s CDJ series to employ the fader start capability. The user can automatically start or stop playback by the sliding cross-fader or channel-fader. Mixer Layout Both the DJM-707 and DJM-909 are similar in layout although the DJM-909 boasts built-in effects and a touch sensitive display. Both mixers also offer a very clean, open fader area for scratching and beat juggling. Both mixers have a session line-in with volume control, cueable master output, mic input, and selectable phono / line switches. In addition, the DJM-909 has a tempo tap button, cueable effects switch, and a plug in for foot switch to control effects. Additional Features of the DJM-909 - TOUCH SCREEN AND BUILT IN EFFECTS A total of fifty different effects incorporated in the DJM-909 can be independently assigned, utilized, & tweaked through the mixers’ user friendly touch screen control. Additional knobs also exist for further parameter adjustments. Revolutionary effect presets range from Fader Synths to Transform and from Touch Phaser to Vocoder. A send/return is also built-in to connect an external effector. - FADER EFFECT Fader effect can be assigned to a channel fader or cross fader from the touch screen so that the faders are capable of controlling and varying the effect’s parameter simply by moving the cross fader or channel fader. - BEAT EFFECT The Beat Effect is capable of synchronizing effects with the BPM for high accuracy effect timing. - AUTO BPM COUNTER The mixer is equipped with an auto BPM counter so users can quickly view the song tempo. Pioneer’s DJM-707 and DJM-909 were designed with scratch DJs, the studio / production DJs and the Turntablist in mind, however they are also excellent units for all DJs wanting to improve their performance level. The introduction of these two revolutionary mixers has taken the high-end battle mixer into a whole new dimension. The DJM-909 and DJM-707 will be available in December at a minimum advertised price (MAP) of $1,199 and $699 respectively. Pioneer offers a complete line of Pro DJ Equipment through its Pro Audio Group. Pioneer offers a limited one-year warranty for Pro Audio products purchased from authorized dealers. For more information: www.PioneerProDj.com. Pioneer Corporation is a leader in optical disc technology and a preeminent manufacturer of high-performance audio, video, computer and cable equipment for the home, car and business markets. The company focuses on four core business domains including DVD, display technologies, Digital Network Entertainment and components. Founded in 1938 in Tokyo, Pioneer Corporation employs more than 34,000 people worldwide. Its shares are traded on the New York Stock Exchange (NYSE:PIO). Pioneer's U.S. headquarters is located in Long Beach, Calif., and its U.S. Web address is www.pioneerelectronics.com. ### Specifications For The DJM-909 and DJM-707 Input Terminal (Input Level / Impedance) CD 1, 2 -14dBV (200mV) / 22k LINE 1, 2 -14dBV (200mV) / 22k PHONO 1, 2 -54dBV (2mV) / 47k MIC -54dBV (2mV) / 3k SESSION IN -14dBV (200mV) / 22k RETURN -7.2dBV (437mV) / 22k Output Terminal (Output Level / Impedance) MASTER OUT 1 (XLR) 2.2 dBV (1.23V) / 60k MASTER OUT 2 (RCA) 0 dBV (1V) / 1k BOOTH/SESSION OUT 0 dBV (1V) / 1k SEND -14 dBV (200mV) / 1kO Headphone Maximum Output (Output Level / Impedance) PHONES 0 dBV(1V)/22 Frequency Response LINE/MIC 20Hz to 20kHz PHONO (RIAA) 20Hz to 20kHz Signal-to-noise Ratio LINE 87dB PHONO 77dB MIC 64dB Distortion Rate CD, LINE 0.02% or less Cross Talk (1kHz) 70dB or more Channel Equalizer (LINE/PHONO) HI -26dB to +6dB MID -26dB to +6dB LOW -26dB to +6dB Mic Equalizer (MIC) HI -12dB to +12dB LOW -12dB to +12dB Power & Physical Power Requirements N. America - AC 120V, 60Hz / Europe - AC 220-240V, 50/60Hz Power Consumption N. America - 31W / Europe - 30W / Japan 27W Dimension (W x D x H) 251 x 381.6 x 107.9 (mm) / 9.9 x 15 x 4.2 (inches) Weight DJM-909 - 6.5 kg (14.3 lbs) / DJM-707 - 6.3 kg (13.9 lbs) plaatjes: www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16236.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16239.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16240.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16244.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16243.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16241.jpg www.lilypix.com/photos/data/d1fe173d08e959397adf34b1d77e88d7/947_p16238.jpg wat vinden jullie van deze mixer? | |
| maximaal 120 tekens. Wel tekst, geen link! | |
| DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 14-11-2026 Berichten: 13458 | 24-10-2003 14:43 |
| Ik hoop dat Pioneer erachter gekomen is dat een voeding niet per sé een straalkachel hoeft te zijn... Ook hoop ik dat Pioneer ontdekt heeft dat 6dB headroom niet echt hoort bij profi spulletjes (20dB komt eerder). | |
| ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 25-10-2003 00:23 |
Dré schreef: Ik hoop dat Pioneer erachter gekomen is dat een voeding niet per sé een straalkachel hoeft te zijn... | |
| DiederikStandaard Lid Uit: Nederland Sinds: 20-5-2003 Laatste: 3-2-2021 Berichten: 615 | 25-10-2003 19:57 |
Reind schreef: Dré schreef: Ik hoop dat Pioneer erachter gekomen is dat een voeding niet per sé een straalkachel hoeft te zijn... Het is te hopen dat Pioneer zich idd wat heeft aangetrokken van de kritiek op de DJM, en dat meegenomen heeft. Ik neem tenminste niet aan dat dit het enige forum is waar wat kritiek is op de DJM 500/600 Wel vind ik de aansluitingen en aanduidingen zo op het eerste gezicht nogal op mekaar gepropt. D'r zit wel logica in, en met alle wenselijke aansluitingen erop (balanced & unbalanced out etc.), maar verder zit het allemaal een beetje op mekaar en door elkaar. Ik had het denk ik niet zo ontworpen. | |
| Wat nu heel gewoon is, was ooit een revolutie | |
| Dj diëgoStandaard Lid Uit: Nederland Sinds: 21-9-2003 Laatste: 3-2-2010 Berichten: 136 | 25-10-2003 20:42 |
nou ik vind em eigenlijk HEEL mooi niet te druk als je het mij vraagt ook een hele mooie display! | |
| Who ever said life is short it's the longest goddamn thing you do, are you gonna do something that's longer! | |
| HendrikStandaard Lid Uit: Nederland Sinds: 15-2-2002 Laatste: 12-8-2013 Berichten: 296 | 25-10-2003 21:47 |
| Hmmm, Als ik ooit met een touchscreen op pad zou gaan dan zou hij wezen voor: 1 M'n lichttafel (maar dat kan ik niet betalen) 2 Voor karaoke (maar dat doe ik niet) 3 Voor MP3 (maar ik spring nog liever voor de trein) Als ik de weg kwijt ben vraag ik wel een dame, koop ik een autokaart of desnoods een navigatiesysteem voor in de auto. Maar ik hoef geen GPS in m'n mixer. Ook nog even serieus. 50 functies over touchsreen????? Allemachtig. Als je die allemaal gebruikt in je sessie ben je volgens mij ook recordhouder "langste DJ-sessie ooit". Die toestanden op de voorkant vind ik buitengewoon eng, achterkant niet echt overzichtelijk. Er zijn natuurlijk heel veel mensen die de DJM500/600 of misschien zelfs de 300 helemaal geweldig vinden, die zullen dit geval vast ook helemaal te gek vinden. En misschien is deze ook wel wat. (als reserve-backup-inval mixer voor in de bejaarde soos, just kidding )Nee, geef mij maar echte knoppen en niet teveel van die doelloze shit erin (kan allemaal kapot gaan joepiedepoepie). Moet tegenwoordig in alles een display zitten? Dan mag ik mijn broodrooster wel eens vervangen. Neemt niet weg dat ik dit ding toch wel even wil testen . | |
| ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 26-10-2003 00:11 |
Hendrik schreef: Neemt niet weg dat ik dit ding toch wel even wil testen . Ik ben wel benieuwd naar deze mixers en helemaal naar hun prestaties. | |
| BramcomStandaard Lid Uit: Nederland Sinds: 8-10-2003 Laatste: 29-12-2008 Berichten: 73 | 27-10-2003 14:48 |
| rond 2004 komt hij (zucht hoe toevallig in januari of december)? maar hij ziet er wel leuk uit (al geef ik tocoh de voorkeur voor zilver en een WIT display. Oranje vindt ik zo oudlullig ^_^ maar goed we zullen toch ff moeten wachten op de eerste reviews, want de specificaties zeggen niet alles ;-) Bram... | |
| SnakeEffect Guru Uit: België Sinds: 17-2-2003 Laatste: 19-4-2014 Berichten: 675 | 27-10-2003 21:26 |
| 't Is niet meer zo erg als vroeger (toen een witte led nog een slordige € 25 kostte), maar een witte LED is duurder dan een oranje. Dit komt omdat wit licht het volledige zichtbare kleuren spectrum moet uitzenden. Me dunkt dat Pioneer wat wilt besparen. | |
| DJ TimStandaard Lid Uit: Nederland Sinds: 9-6-2003 Laatste: 27-11-2012 Berichten: 1105 | 27-10-2003 21:33 |
| Ziet er strak uit! Zou hem best wel eens in mijn vingers willen hebben. Ik hoop dat Pioneer nu wel de goeie kant opgaat met hun mixers. | |
| Ik ben niet het eerste wereldwonder maar ben er wel geweest | |
| DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 14-11-2026 Berichten: 13458 | 27-1-2004 21:56 |
| Jeroen is vandaag langs geweest met de 909. OK, ik ben onder de indruk (echt waar). Zo ongeveer alles is in te stellen (fader curve, cross-fader curve, cross-fader cutpoint). Cross-fader is optisch (via encoder) en voor de kanaalfaders zijn gekozen voor de bekende (en betaalbare!) Alpha Proglide faders (zitten ook in de UMX reeks en een aantal andere (soms erg dure) mixers). Het "eindkraken" (faders die gaan kraken doordat de gebruiker als een lompe boer naar de uiteinden ramt waardoor na verloop van tijd de print op die plek weg begint te buigen) wordt verminderd door de schuifblok mechanisch tegen te houden, buiten de behuizing van de fader, voordat het begin/einde van de faders gehaald wordt (een truc die ook Ecler, Stanton en nog een paar anderen al een tijdje toepassen). Kanaalfaders zijn eenvoudig en live te vervangen. Effecten waren ronduit indrukwekkend. Ik ben niet zo'n effectenman MAAR wat ik Jeroen zag doen met de mixer (ondanks dat hij zelf toegaf nog niet echt thuis te zijn in deze ook voor hem nieuwe mixer) klonk toch erg leuk en hier en daar ronduit "applaus waardig" ;-) Je hebt per fader een effect-unit EN een mogelijkheid om over het totaaltje nog een externe effectbak te gooien. Touch screen display werkt prettig maar heeft een vrij beperkte inkijkhoek (dus goed te zien voor de gebruikers maar minder voor de omstanders (lekker belangrijk)). De mixer weegt een ton en kost dat helaas ook. Is het de "ultieme" battle mixer? Nou, qua instellingen en faders (waarbij de friction van de cross-fader trouwens instelbaar is!) zit het goed in elkaar EN de effecten zijn prima. MAAR voor dat geld MAG DAT OOK WEL! | |
| DiederikStandaard Lid Uit: Nederland Sinds: 20-5-2003 Laatste: 3-2-2021 Berichten: 615 | 27-1-2004 21:59 |
Enig idee wat wij normale (nou ja ) mensen ervoor moeten gaan betalen? | |
| DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 14-11-2026 Berichten: 13458 | 27-1-2004 22:03 |
| Volgens mij rond de 1500 euro. De 707 krijgt overigens dezelfde instelmogelijkheden maar zal het moeten doen zonder de effect unit. | |
| Dj JoBoStandaard Lid Uit: Nederland Sinds: 8-12-2002 Laatste: 28-2-2009 Berichten: 192 | 28-1-2004 16:32 |
Dré schreef: Jeroen is vandaag langs geweest met de 909. OK, ik ben onder de indruk (echt waar). Zo ongeveer alles is in te stellen (fader curve, cross-fader curve, cross-fader cutpoint). Cross-fader is optisch (via encoder) en voor de kanaalfaders zijn gekozen voor de bekende (en betaalbare!) Alpha Proglide faders (zitten ook in de UMX reeks en een aantal andere (soms erg dure) mixers). Het "eindkraken" (faders die gaan kraken doordat de gebruiker als een lompe boer naar de uiteinden ramt waardoor na verloop van tijd de print op die plek weg begint te buigen) wordt verminderd door de schuifblok mechanisch tegen te houden, buiten de behuizing van de fader, voordat het begin/einde van de faders gehaald wordt (een truc die ook Ecler, Stanton en nog een paar anderen al een tijdje toepassen). Kanaalfaders zijn eenvoudig en live te vervangen.Effecten waren ronduit indrukwekkend. Ik ben niet zo'n effectenman MAAR wat ik Jeroen zag doen met de mixer (ondanks dat hij zelf toegaf nog niet echt thuis te zijn in deze ook voor hem nieuwe mixer) klonk toch erg leuk en hier en daar ronduit "applaus waardig" ;-) Je hebt per fader een effect-unit EN een mogelijkheid om over het totaaltje nog een externe effectbak te gooien. Touch screen display werkt prettig maar heeft een vrij beperkte inkijkhoek (dus goed te zien voor de gebruikers maar minder voor de omstanders (lekker belangrijk)). De mixer weegt een ton en kost dat helaas ook. Is het de "ultieme" battle mixer? Nou, qua instellingen en faders (waarbij de friction van de cross-fader trouwens instelbaar is!) zit het goed in elkaar EN de effecten zijn prima. MAAR voor dat geld MAG DAT OOK WEL! Was idd erg indrukwekkend wat hij met een mixer doet (zelfs als hij gewoon op een cdj-20'je staat )Dat touchscreen is echt heel handig, ik hoor van veel mensen wat een flauwekul zon touchscreen op een mixer! maar dat bevordert het mixer alleen maar. Ook een grappig ding is dat alles aan en uit te zetten is. Eq, Efx en kanaal 1 en 2. Ook zijn de eefecten vanaf de 40 fader gestuurd, dus als je dan met een fader naar keuze (1/2 of X-fader) beweegt krijg je een effect of als je hem verder omhoog zet krijg je meer effect. De effecten zijn allemaal optimaal instelbaar via de maten (1/8, 1/4 enz enz) en als je het vervelend vind dat de bass meedoet met de echo zet je dat ff uit Wat ik trouwens niet echt met je eens ben dre, is de inkijkhoek. Dat is dus instelbaar met de draaiknopjes op de achterkant van het mengpaneel. Dat werkte perfect! | |
| DJM 909 krijgt een adviesprijs van 1500 707 van 900 dacht ik... | |
| DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 14-11-2026 Berichten: 13458 | 29-1-2004 09:58 |
Dj JoBo schreef: Ah! Jij moet dezelfde demo van jeroen gehad hebben als ik?!Was idd erg indrukwekkend wat hij met een mixer doet (zelfs als hij gewoon op een cdj-20'je staat )Wat ik trouwens niet echt met je eens ben dre, is de inkijkhoek. Dat is dus instelbaar met de draaiknopjes op de achterkant van het mengpaneel. Dat werkte perfect! Klopt MAAR als je hem voor jezelf op optimaal zet dan is hij voor iemand die ernaast staat niet echt optimaal te lezen. Om maar eens een extreem voorbeeld te noemen: Bij mijn SyncMaster 172T kan ik nog vanaf de zijkant alles lezen (wat, nog even en ik kan vanaf de achterkant alles lezen ;-)Gezien de prijsklasse had een mooie TFT of OLED er toch wel vanaf gekund... | |
| Michel van de beekStandaard Lid Uit: Nederland Sinds: 31-8-2002 Laatste: 23-8-2011 Berichten: 72 | 29-1-2004 10:38 |
| En hoe klinkt ie ? Niet alleen bij normale uitsturing maar ook bij standje DJ (rood, roder, ben je gek!) Want de meeste pioneer mixers die ik (helaas) heb moeten horen waren te erg om woorden aan vuil te maken (zie ook: www.pbaudio.nl/pbviewnewsmsg.aspx?cmd=viewmsg&msgid=102 ). Ergonomie is wel weer top ... en daarom zijn die krengen ook zo geliefd. | |
| DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 14-11-2026 Berichten: 13458 | 29-1-2004 12:22 |
| Er zijn geen metingen verricht en de mixer hing aan een setje skypech monitortjes (inpakafdeling). Gehoormatige tests ga ik me niet aan wagen (ik weet te goed wat de verhouding in het percentage "luisteren met je hersenen vs. je oren" is (zolang het niet dubbel blind is vertrouw ik de uitslag per definitie voor geen meter)). Meettesten wil ik zeker nog eens op een aantal mixers uit gaan voeren (o.a. headroomtest PER ONDERDEEL van de mixer). Maar daarvoor moet dan eerst een kloppend protocol geschreven worden (peer reviewed en zo) voordat ik me daar aan waag. Ik zit dan te denken aan (de eerder genoemde) headroom per onderdeel, S/N totaal/nominaal, S/N onderdelen, THD, IM, TIM, Freq. response, Fase response, dynamiek etc. Dingen die je goed kunt quantificeren zonder dat er sprake kan zijn van een bias. | |
| MayodaEx Lid Uit: Nederland Sinds: 19-12-2003 Laatste: 30-9-2004 Berichten: 75 | 29-1-2004 14:33 |
| Pffff 1500 euro , zijn ze helemaal gek geworden ofzo! Volgens mij komen we nu toch wel op het punt dat het en beetje TE gek wordt allemaal. voor 1500 euro, koop je een mackie tafel Bovendien ben je met een kaosspad 2 en bijvoorbeeld een vestax met aux send/returns in het kanaal toch een stuk minder kwijt en ik denk dat de toepassingsmogelijkheden ongeveer gelijk zijn. Leuk hoor al die cut points etc etc , maar grandmasterflash kon het ook zonder. Je krijgt straks hele generaties van mensen die duizenden euroos apparatuur hebben staan en een resultaat laten horen dat niet veel verschilt van andere dj`s met doorsnee spullen. Ik bespeur die trend ook een beetje in producerland de laatste tijd, bij veel mensen veel te veel poespas en van die zelfde mensen heb ik dan nog nooit een nummer gehoord omdat het ze niet lukt. Ik denk dat de beginner deze mixer niet kan betalen en dus niet koopt , en ik denk dat de gevorderde/pro dj door dit apparaat heen zal prikken, er zijn namelijk tal van andere goedkopere middelen om hetzelfde te bereiken ...........................TOO FUCKING EXPENSIVE!! p.s en dan mag je hopen dat ze dat vreselijk schelle rotgeluid uit de djm500/600/3000 hebben weten te krijgen! | |
| MayodaEx Lid Uit: Nederland Sinds: 19-12-2003 Laatste: 30-9-2004 Berichten: 75 | 29-1-2004 14:39 |
| Daar heb je de eerste maar al........................ KAOSSPAD 2 heeft gewoon 50 effecten meer dan de nieuwe pioneer. Een vestax in combi met een kaosspad 2 is dus al krachtiger dan een 909 Misschien geen frictie instelling , maar wel 50 effecten meer onder je duimen en evengoed kwalitatief hoogstaand spul. | |
