Crest CC2800 ervaringen?
(29 reacties. Pagina 2 van 2)
RutgerStandaard Lid
Sinds: 12-9-2003
Laatste: 24-1-2018
6-7-2008 21:13
hugovanmeijeren schreef:
Ik zou die Peavey (immers daar komt Crest tegenwoordig weg) bakken lekker laten staan en als je Crest wilt kijken naar de CA of Pro x001 series kijken.
Draai al jaren met volle tevredenheid op CA series (CA6, CA9 en CA12).
Groeten Hugo
He hugo heb je ervaring met de crest cc?
en heb je dit stuk wel eens gelezen?
quote
Geachte heer Molema,
De Crest CC-serie is een nieuwe versterkerlijn en nog onbekend bij Engine
onze TD (goed teken). Derhalve heb ik informatie met betrekking hiertoe
aangevraagd bij Crest. Onderstaand verhaal is dus in het Engels. Ik hoop dat
u hier wat aan heeft.
Met vriendelijke groet,
TM-Audio
t: 030-2414070
f: 030-2410002
www.tmaudio.nl
Pro200(tm) was designed after old Pro series (let's call it Pro01),
combining the analog output stage of Pro01 with a new designed resonant
switch mode power supply. The output stage similar to Pro01 in Pro200 is
available in class AB for the smaller models (3301, 4601, 5200) and class H
for higher power models (7001, 8001, 9001, 7200, 8200, 9200). The mayor
advantage of Pro200(tm) over Pro01 is size and weight, the mayor
disadvantage is low frequency punch. Now, while there is no doubt about the
former, the latter can be discussed:
Pro200(tm) in a true Crest fashion has an overbuilt power supply and is able
to generate a voltage swing higher than needed to achieve specified power.
This will help the amplifier to produce musical peaks, which let make it
sound louder than competitive designs - more juice, more fun! For a very
long bass signal however, the storage of an "iron" transformer will support
the caps storage and the bass response of an analog power supply design
might be appreciated.
This brings us to CC(tm)-Series. CC(tm) basically is a Pro200(tm) with an
analog PSU built in China. It does have the overbuilt PSU again. Now, does
that mean CC(tm) is the same as the old Pro01? No, not really... What is the
main difference? 20 years!
CC(tm) is very close to Pro200(tm), and it uses the Pro01 power supply
technology. That's how we should describe it. The mayor difference is
between the 1987 Pro01 design and the 2001 Pro200(tm) design. Saying this,
8001 lovers will love CC4000. It will produce more power, at a sound
experience very close and just slightly more than half the weight! That's 20
years of experience!
N.B.: The main reason generation 1 "switchers" (mainly Carver) were not
taken serious in the market, was the low frequency response. Generation 2
Switchers (QSC) made it to market leaders, so the acceptance for this design
went all the way up, and customers learned to live with the disadvantage.
Now, these designs were not only short of the big bang in the low end, but
also did not have any overbuilt power supply. They were built to perform on
the bench and they actually never cheated! In musical applications however,
you will notice a high voltage swing. Crest has always overbuilt power
supplies with the exception of CPX. The latter is limited in power like
competitive designs. All other models will always give you more watts in
music than the spec sheet will claim. And last but not least, from all SMPS
models in the market, I think Pro200(tm) actually comes very close to an
analog supply sound and power
DjbramStandaard Lid
Sinds: 14-12-2005
Laatste: 29-5-2014
21-9-2008 12:18
indemiddels al iemand die meer varing heeft met de CC-serie zoals bv de cc-4000
t' gaat zoals t' gaat
TBStandaard Lid
Sinds: 11-5-2003
Laatste: 14-1-2018
12-11-2008 08:28
Ik heb inmiddels vier cc-4000's. Wat wil je precies weten?
Hebben tot nu toe max gedraaid op ca 2500 watt op 4 ohm gebrugd.
Het eerste defect heeft zich inmiddels gemeld: Eén Signal-LED weigert nu te branden.
DjbramStandaard Lid
Sinds: 14-12-2005
Laatste: 29-5-2014
12-11-2008 12:05
Ik ben inmiddels overstag gegaan op de "oude" crest pro serie ( 4601/7001/8001 )
SisStandaard Lid
Sinds: 17-9-2003
Laatste: 20-1-2019
12-11-2008 12:34
helemaal geweldig, vooral die 8001 op de subs happy :)
sis
Freelance muzikant, producer, componist .
HugovanmeijerenStandaard Lid
Sinds: 11-7-2004
Laatste: 19-5-2014
13-11-2008 11:23
sis
Uhu. razz :p
Groeten Hugo
Laatste: 30-8-2026
Maarrr... bijna 40 kg voor een versterker van 2x 1.250 Watt? shocked 8O
DjbramStandaard Lid
Sinds: 14-12-2005
Laatste: 29-5-2014
13-11-2008 13:21
ster weer beestje a 8001 opgehaald sneaky :V
Maar inderdaat een rackje 8001/7001 is niet te tillen. Maar je moet er wat voor over hebben laten we maar zeggen laugh :D
TBStandaard Lid
Sinds: 11-5-2003
Laatste: 14-1-2018
14-11-2008 07:33
Trapje op met zo'n rack lijkt me geen pretje! Overigens zijn de CC's ook niet extreem licht, rond de 20 kg. Komt door de conventionele voeding.
Staat echter in schril contrast met de oude pro 001 serie. Wij hebben ooit een veel te groot 15HE-rack gehad met 3 x Pro4001 en deze drie verdiepingen hoog moeten tillen... Vervolgens afgesproken: Of een ander amprack, of nooit meer trappen...
Ronny BStandaard Lid
Sinds: 23-3-2004
Laatste: 25-7-2017
29-12-2008 22:39
Heb hier twee maal CC2800 staan.
Deze draaien allebij 4 ohm burg op het laag.
(sturen 2x RCF 18inch aan. type L18s800)
En dit tot tegen de clip. geen enkel probleem.
Worden niet overdreven warm.
in mijn ogen kun je hier dan ook geen miskoop aan doen.
Ron
